October 10, 201214 yr When kicking the bike over you can feel it kind of "crunch" and engage normally, and occasionally the kickstart gets stuck halfway down, as if the teeth of the kickstart have popped out and havent engaged properly. Anybody have any advice on what will/might need replacing? I can take it all apart no problem, but unless its blindingly obviously broken I wont really know what needs replacing.
October 10, 201214 yr More than likely you have knackered a few teeth on the kickstart gear, if so replace it and the idle gear next to it. Also check your clutch cover for a crack going from the hole the kickstart goes through upto the bolt above.
October 10, 201214 yr I've had a similar problem once, not a trials but they're all very similar as far as I've seen. Turned out to be a sheared tooth. If your competent to take it apart then I'd strip it and have a look, at the end of the day ya gonna have to strip it down to repair it anyway so... Hope it's something simple!
October 10, 201214 yr Author More than likely you have knackered a few teeth on the kickstart gear, if so replace it and the idle gear next to it. Also check your clutch cover for a crack going from the hole the kickstart goes through upto the bolt above. K thanks, will do. Replace the idle gear regardless or just if its damaged? Hopefully the clutch cover isnt cracked as I have a Raga and could be a pain to source a new one at a reasonable price lol.
October 10, 201214 yr Idle gear can look fine from the front, but be a bit of a mess behind. On my old gasser I replaced 3 clutch covers. The idle gear might of saved 2 of them and The idle gear is a lot cheaper that the clutch cover. The normal cover might fit your raga.
October 10, 201214 yr Yep its common and best remove clutch and then idle gear and inspect the inner side as you will only see outer side. The kickstart gear is usually ok but as said if both or one wears then it tends to crack the clutch case. Been there done it all. Generally down to poor starting method.
October 10, 201214 yr In my experience the problem arises from "stamping" on the kick start instead of gently engaging it first and then pushing down in one smooth motion. Every time I see someone stamp on it I cringe!
October 11, 201214 yr Author Yeah I've not owned the bike long and am generally pretty gentle starting it as I've read its a problem when stamping, so is obviously down to the previous owner
October 12, 201214 yr If you do have broken teeth, do not ride the bike, and find the small bits before they get into the tranny gears, as bad things happen!
October 12, 201214 yr Could the shards of metal not of come out in a previous oil change though. Still worth a good look mind.
October 12, 201214 yr Author Gonna strip it down this weekend. Ill need to drain the oil before taking off the clutch cover presumably or if I lay the bike over will I get away with it staying in? It's only a few hours old but I guess if its gotta come out its gotta come out!
October 12, 201214 yr Yes you can lay it on it's side and leave the oil in. But if you are going to need to change parts it may be better just to drain it.
October 12, 201214 yr There are some vids on YouTube showing how to do what you are about to do. Worth a watch, Gas Gas usa I think it was uploaded them. And like cope said have a look for metal fragments.
October 12, 201214 yr Author There are some vids on YouTube showing how to do what you are about to do. Worth a watch, Gas Gas usa I think it was uploaded them. And like cope said have a look for metal fragments. Thanks alot thats brilliant, just found the one about removing the clutch to get to the kickstart etc, very helpful as tbh I would have just gone on a whim of how to do it, and it looks pretty easy without taking the clutch basket apart. Many thanks.
October 12, 201214 yr I had to remove my casing to fit a water pump seal and its really simple and straight forward. The only minor faff I came across was the rubber between the bash plate and bottom of the engine was a slight hindrance on re-fitting because it was squished against the casing. It just made it slightly awkward getting the casing on square without damaging the gasket. A little bit of patience though and it got there in the end.
