Gas Gas 80
Hi when the bike starts from cold it revs really high for about 5 seconds then runs normal. It has done it since replacing the throttle cable. Any ideas, thanks!
are you sure you ran the cable EXACTLY like the old one was?
my Gas Gas does this. (06' 280)
and ive read on here that others have this problem too.
when you kick it over and the revs start rising, shake it side to side...it will settle down to idle quicker.
trust me :)
sounds like the slide is not bottomed in the carb
and allowing more air into the engine
check the cable at both ends , routing ,
Thanks sorted now. It was the carb, it had turned slightly when we changed the throttle cable.
