May 15, 200521 yr Hello, can any one recommend any thing to de coke an exhaust, the Header/down pipe of my 280 in choked with carbon, i can scrap a lot any with a scrrew driver but need some thing to reach round the bend. Thanks Steve
May 16, 200521 yr get a bendy bit of metal and scrape it round the bend, then get a power washer and blast it all out. then make sure all the water is out before you put back on your bike
May 16, 200521 yr 8" to 10" length of twisted steel cable fitted into a drill chuck. Untwist/fray the other end to make a swirling mass of skin/flesh remover and *carefully* insert into the front pipe. Ideally, the pipe should be in a vice so that you don't have to worry about visiting the A&E department of your local hospital
May 16, 200521 yr Ideally, the pipe should be in a vice so that you don't have to worry about visiting the A&E department of your local hospital You've been there haven't you? Come on then K, tell us what you did.
May 16, 200521 yr A safer method (provided you don't drink the caustic soda) is to pour some caustic soda into the pipe and chuck in some small(ish), sharp(ish) stones, seal the ends and shake like crazy.
May 16, 200521 yr Ideally, the pipe should be in a vice so that you don't have to worry about visiting the A&E department of your local hospital You've been there haven't you? Come on then K, tell us what you did. It was a friend of my uncle that told the neighbours daughter's boyfriend who delivers our morning paper
May 16, 200521 yr For Kinell the decoke method of preference appeared to be falling off and leaving the bike spinning round in circles on full throttle for a few minutes.
