Cota 200 Amal Mk1.5
Does anyone know the idle jet size for this bike? please, I cant get mine to run right without the mixture screw right in even after prelonged attempts of cleaning the jet. Mine has a 25 fitted at present.
Thanks in advance.
Jimbo
According to my mh123/200 manual, the carb spec is as follows :-
Make - Amal 6264/402
Diffuser diameter - 24mm
Main jet - 135
Low speed jet - 20
Gas valve - 3
Sprayer - 106
Needle - 4a (2B1)
Hope this helps
Jimbo
Main jet - 135
Low speed jet - 20
Gas valve - 3
Sprayer - 106
Needle - 4a (2B1)
Hope this helps
thanks for the info but my bike has the earler MK1.5 carb and your is a MK2 so the jetting will be different,
iam coming up with 38
Well that would answer my question then as the 25 will be way too small. I better check the others too if you know them as Im starting to think this carb may be off another bike. Although it does run very well.
Ok been doing a bit of research and my carb isn't the correct carb unless anyone can tell me otherwise. The carb has 2 screws holding both the top of the slide and the float bowl and looking at the online manuals it should have a top similar to a mk2 and the bowl should be held on with a wire clip.....anyone ?
you should go on a amal spares website i use burlen it has good diagram of parts and differnt carbs ,from what i have found the early 200 has a mk1 amal 2 screws in top and 2 in bottm ,later 200,s have a mk2 black screw on top with a large nut holding bowl on
