Scorpa 280 Sr
Got the above,anyone ever have to retard one or am i getting too old.
It's not the initial pick up which is quite perky,but mid range is instant.
Cheers.
I thought if anyone knew about Retards it would be you. Sorry cant be of any help though .
You could Richen the needle as well. If the jetting is spot on now, richer will slow down the pickup a bit.
Think your just getting to old Alan, you would be better of on jocks dinosaur?
Tie a knot in the throttle cable so you can't rev it so much !
At least laser has a constructive suggestion,the rest of you wouldn't know a trials bike if it run you over.
I would be reluctant to touch carb settings as it runs so nicely.
I was hoping someone had retarded (Good word in this company)one,and how it went.
No more replies from Jockland please.
I'm not being funny but have you run it past Birkett's .
He might have a solution for you I've phoned him on a couple of occasions and was really helpful.
You on about a Rotax powered SAcorps? Yes, kick the timing back all the way!
Apologies,it's a 2011. I didn't make that clear.
If it's the auld sherco engine, pull the flywheel off,
mark where the stator is, slacken the 3 bolts, then move the stator plate about 5mm, rebuild and try it out. It made a difference to my 04, 06, and 09 bikes.
Oh it's the Sherco motor then! Yep, Demmo is right. There should be a mark on the stator plate that aligns with the right edge of the casting web on top. I usually tell folks , a change(counter rotation to retard or slow) of 1-2mm(mild), 3-4mm(mid) or 5-6mm(most), so adjust accordingly. Seems a 1mm change is not really enough to tell. :beer:
  • 4 weeks later...
If you are wanting to slow it down a bit, you might put a slow turn throttle on it, that is if you have a fast one on there now. The white tubes are the fast one and the black are slow.
