Cota 348 Clutch Oil
As this bike has been standing for years i'm going to change oils.On clutch side how much oil is needed and spec, also the same on the gearbox?
Gearbox sae80 gear oil 300mL
Clutch automatic transmission fluid 300 mL
My book says 300 in gearbox 90w and 200 in the clutch 10w 30 and with that frame # it's a 1976
  • 1 year later...
I was thinking about trying ATF oil instead of the 10W 30 oil in the clutch side. Any advice welcome if this is a good or bad idea !
