January 20, 201313 yr not really the end of the world if the casing is rotton as £80 fixes it . i wouldnt walk away from an otherwise good bike just for the sake of the casing
January 20, 201313 yr I'm just asking for a friend. Is the state of Beta quality control really that embarassing?
January 21, 201313 yr build quality and trials bikes don't really go hand in hand unless you get a 4rt, that should set hares running!
January 21, 201313 yr I have an 03 200 Rev 3 with alloy case with no problems But my friend has a later 08 with a magnesium case and it leaked under the waterpump hose There is a coolant just designed to prevent this problem Edited January 21, 201313 yr by naichuff
January 21, 201313 yr Use gloss paint as coolant. That way it will seal up any leaks as you go. I am joking of course!
January 21, 201313 yr Lookin for a secondhand bike between £1500 and £2000 for a friend. Havent decided what yet but can anyone recall which is the first year rev 3 not too have the corrosion problem caused by the coolant ? I think the question may need to be inverted; i.e. what is the latest year of Rev3 not to have this problem. I too replaced a case on a 2008 bike which was the last of the Rev3s before the Evo was introduced in 2009.
January 21, 201313 yr He repaired the case with a metal bond stuff The other fix was to use the early alloy case if they are still available
January 22, 201313 yr Betas with rotten cases? This is a new one on me, what with stators packing up cracking frames, kickstart on the wrong side, I would buy a Gas Gas TLTEL
January 22, 201313 yr Use propylene glycol based premixed coolant like Engine Ice or Silcolene Pro-Cool and there is no problem. Tap water is the devil's coolant! I'm still curious where the magnesium that is being leetched away from the cases is being deposited.
January 23, 201313 yr Betas with rotten cases? This is a new one on me, what with stators packing up cracking frames, kickstart on the wrong side, I would buy a Gas Gas TLTEL I think you'll find Beta puts the kick start on the proper side as it's better. Beta=Better!
