suzuki250 Posted January 24, 2013 Share Posted January 24, 2013 Does anyone know what the part numbers are for the main bearings on a c15 (side points model)? Quote Link to comment Share on other sites More sharing options...
broony Posted January 24, 2013 Share Posted January 24, 2013 According to the bible(Rupert Ratio) the bearing is a 6305.Simply Bearings have a good selection of bearings at realistic prices.I fitted a smaller primary sprocket so had to take a bit of the crankcases and instead of fitting a seal I used a sealed bearing and removed the seal nearest the crank. cheers the noo Brian Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted January 25, 2013 Author Share Posted January 25, 2013 thanks Quote Link to comment Share on other sites More sharing options...
