February 21, 201313 yr hi took both wheels apart to powdercoat rim and hub and didnt realise the rim is often offset from the hub side to side. never noted this before dismantling, anyway i suppose the important thing is, does the rims on a 4rt sit perfectly central to the swingarm? ..........catch my drift..? cheers steve
February 21, 201313 yr I'm sure there is a drawing with this in the manual- sure there is PDF version on line somewhere
February 21, 201313 yr On this site: http://montesa4rt.nl/ Klick on "documentatie", followd by "handleidingen" and then on "2005 Cota 4RT" to download the PDF file. After that go to page 5-15
March 3, 201313 yr Author spot on thanks guys, those drawings are excellent as youd expect from honda
March 5, 201313 yr Front rims are almost always centered on the hub, rear rims are often offset to provide more tire clearance for the sprocket. Section 5 page15 in the above manual provides the rear wheel set up dimension.
