Po Go Pro
Evening all. Was in a trial today on my 09 txt300 and half way through the shock went and turned into a pogo stick. Do you know if it can be rebuilt and if so by who?
Thanks
Is it the standard sachs shock that you have or do you have an ohlins shock? The ohlins can definitely be rebuilt i had mine on my last bike rebuilt twice due to it dumping all its damping oil which sounds similar to whats happened to you. Im pretty sure the sachs shock can also be rebuilt but not entirely sure who by though. If you search for shock rebuilders or specialist near your area and give them a call you might be able to get some help or find someone who will rebuild it for you
