March 13, 201313 yr have had a trusty 315 for 11 years now, great bike but the front brake is very average. This was made very apparent when my son got a 125 Sherco on which the brakes are outstanding. Have just fitted new EBC pads which made no difference. Any tricks ? Caliper ? Master cylinder ? anything else ? Cheaper the better of course as its only an old girl I play on occasionally. thanks
March 13, 201313 yr Do the pistons slide easely in the caliper? Are they not stuck from dirt build-up? Another option is a master cylinder with a smaller diameter plunjer. (if that exists) Also, but not cheap: http://www.splatshop.co.uk/xblok-billet-racing-caliper.html Back to galfer pads maybe...
March 13, 201313 yr Author Do the pistons slide easely in the caliper? Are they not stuck from dirt build-up? Another option is a master cylinder with a smaller diameter plunjer. (if that exists) Also, but not cheap: http://www.splatshop...ng-caliper.html Back to galfer pads maybe... contacted splat about that caliper, it is not available at the minute they were helpful and recommended http://www.splatshop.co.uk/ajp-4-pot-calliper-assy.html its not mad money as long as it fits straight on and gives a sharper brake has anyone tried this on a 315 ?
March 13, 201313 yr It should fit because it's the same caliper that's on the 315R made after 2001. Don't know if the master cylinder also changed after 2001...
