March 24, 201313 yr I got the info direct fom the Canadian importer, it is for all models, not just the 2013, details at this link: http://www.ossacanada.ca/Ossa%20General%20Quick%20Tips%20Guide%20R5.pdf
March 24, 201313 yr Been running Motorex full synthetic at 125;1 in both the 2011 and 2012 280i with no problems.
March 25, 201313 yr Been running Motorex full synthetic at 125;1 in both the 2011 and 2012 280i with no problems. I leave more oil in the measuring cylinder than that !!!
March 25, 201313 yr 140:1 is fine for trial for the Ossa, use a high quality synth 2T oil. After you warm it up make sure you "rev it out" to clean out any deposits etc from the warm up / choke period. Many riders forget to do this and slowly their exhaust will plug, motor does not breath as it should and you have problems. Hope this helps.
March 25, 201313 yr 140:1 is fine for trial for the Ossa, use a high quality synth 2T oil. After you warm it up make sure you "rev it out" to clean out any deposits etc from the warm up / choke period. Many riders forget to do this and slowly their exhaust will plug, motor does not breath as it should and you have problems. Hope this helps. How did bikes ever run at 25:1 mineral oil ? Edited March 26, 201313 yr by b40rt
March 25, 201313 yr Author 140:1 is fine for trial for the Ossa, use a high quality synth 2T oil. After you warm it up make sure you "rev it out" to clean out any deposits etc from the warm up / choke period. Many riders forget to do this and slowly their exhaust will plug, motor does not breath as it should and you have problems. Hope this helps. Ok, I will use 140/1... True is that Ossa with petrol mix 100/1 has problem with choke after a while on little gas... Then I pull full throttle until the engine running smoothly... In fact, life time of spark plug NGK br5es was about 40 hours. Im curious, it will be better with petrol mix 140/1... Edited March 25, 201313 yr by koby
March 25, 201313 yr Author Ossas recommendation is 140/1 ;-) I think my bike is ok, because I know three Ossa bikes and all have problem with totaly black piston and short life time of spark plugs... I think there is behavior. :-( But its off topic.
March 25, 201313 yr 140:1 is Ossa's recommendation to me. For the fuel, on ECO19 software there is a fuel co-efficient adjustment from 95% to 105%. On ECO17 software set the TPS at 6 to 7 deg - will do the trick. cheers
March 26, 201313 yr Author borus: Ok, but I have map 11, because I have old CDI and map 11 is supposedly the last map for my version CDI . At least my dealer say it... :-/ I must change ECU for be able to record the last software... no? Edited March 26, 201313 yr by koby
March 26, 201313 yr Map11 is definitely not the last map available for the old ecu, borus will confirm but I think there is at least a map15
March 26, 201313 yr We have maps for both versions of software since Jan 2013. Neither map 11 or 15 are current.
May 31, 201313 yr Ossas recommendation is 140/1 ;-) I think my bike is ok, because I know three Ossa bikes and all have problem with totaly black piston and short life time of spark plugs... I think there is behavior. :-( But its off topic. You guys must have a different version of the manual to me, I have a 2011 and 2012 book and both say 110:1
May 31, 201313 yr HI Deon: It's not in the manual, the info came directly from Ossa Canada, there is a document on the Ossa Canada website with the info at this link: http://www.ossacanada.ca/Ossa%20General%20Quick%20Tips%20Guide%20R5.pdf
June 3, 201313 yr Only just read this topic (I don't have an Ossa) but 'Accustafil' is the only packing I'd use in a silencer (Buells and Ducatis blow anything else out). Wrap it snug, but not too tight and hold it in place with a little masking tape which will burn out.
