March 17, 201313 yr Does anyone have a photo of exactly where the rubber cushions fit between the bashplate and bottom of the engine? I’ve tried to fit them like the best I can make out from the pictures in the manual, but whenever I put the bashplate on the small one seems to slip around. I normally pull it out so that I don’t lose it during a trial. Cheers
March 17, 201313 yr I hope these pictures can help you: http://www.trialscentral.com/forums/gallery/album/141-position-of-rubber-bashplate-cushions-on-4rt/ Normally the rubbers are glued to the bashplate
March 17, 201313 yr Author Thanks Guys that is most helpful.Glueing into position would keep them in place, but I can see from your pictures that they seem to there is quite firm contact from the bottom of the engine. I;ve printed the photos for next time I change the oil.
March 17, 201313 yr Position looks ok but also looks like a std bash plate. A mitani or similar will not distort as much and hence not compress rubbers so much. I have in the past siliconed mine in place especially if you straighten out a used bash plate.
