April 9, 201313 yr Just bough a txt 280 2001 and looking for new front and rear sprocket but can't find any listing on the net for any pre txt pro models will they still fit also fork leaking abit and changed to seal but still leaking think I might have bought cheap set any where can get original gas gas ones ? in the uk many thnaks
April 9, 201313 yr http://www.gasgasmotos.es/en/manuals/download-2001_txtpro_partlist1.pdf.html Just google the part number 9 times outta 10 you'll find a link to what ya need Edited April 9, 201313 yr by tazz229
April 10, 201313 yr Author found out that the rear sprocket is a TR210 Black - 41T which is a 6 bolt the newer txt pro is only a four bolt set up
April 11, 201313 yr just had the same problem getting the 6 bolt rear sprocket for my JTR, Loooked at quite a few sites and there didnt appear to be much available. Was looking for a 40t rear , ended up buying a 42 tooth listed as a Sherco sprocket. have since seen them on Splatshop site and sandifords are selling them on Ebay. TLTEL
