jeffers Posted June 3, 2013 Share Posted June 3, 2013 Hi all, Just curious about castrols recommended 2 stroke oil for the 250 Evo, There first recommendation is Power 1 scooter, they say that scooters do a lot of stop/start and the oil is very good for this type of riding (Trials) and has excellent non exhaust clogging properties, There alternative recommendation is Power 1 Racing Just wondered if anyone has used the scooter oil,(opinions) They also say Ratio 66:1 but on the bottle it says upto 50:1 Just getting back into trials from a long time at enduro, I used power 1 racing for enduro, is this oil OTT for trials Many thanks Jeffers Quote Link to comment Share on other sites More sharing options...
0007 Posted June 3, 2013 Share Posted June 3, 2013 I bet the scooter oil is for oil injection systems, not pre mix I wouldn't use it Quote Link to comment Share on other sites More sharing options...
billyt Posted June 4, 2013 Share Posted June 4, 2013 Scooter Oil ? I concur with 0007. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted June 4, 2013 Share Posted June 4, 2013 The scooter oil will be fine. It will be less viscous than power 1 as scooter oil is pre diluted so it is fluid enough to be pumped through the oil pump on scooters. This pre dilution may be why Castrol suggest 50:1 rather than 66:1. Mixing ratios often causes quite a bit of disagreement. The fact is no mix ratio is ideal for all occasions. (that is one reason a pumped system Is preferred on road bikes). If all you do is potter about with the odd 2 second burst of revs up a climb then 80:1 may be OK. If you are going to thrash your bike round the Scott with a clogged radiator 25:1 is wiser. I would never go leaner (less oil) than either the bike manufacturers or oil manufacturers recommendation, whichever is the richer. Cheers Quote Link to comment Share on other sites More sharing options...
