June 9, 201313 yr The spring on the levers is quite weak. I use an O ring just bigger than the ball on the end of the lever. push it over this and push down to adjuster wheel and stretch it over onto the second part of the lever. Makes everything feel much better and as cheap as chips to replace. Just a fiver for that thanks !!!!!
June 10, 201313 yr you sound full of useful tips, have you got any for setting a carb up on a 2012 300cc gas gas racing ?
June 10, 201313 yr 125 main 45 pilot 3 slide mid posn on the clip check float level at make the float bowl nut have more access to fuel
