June 24, 201313 yr what can i do here? its had little use by a clubman rider :/. if you look closely theres a tiny gap inbetween the paint its about 1mm at most but its still a crack!! Edited June 24, 201313 yr by shercoben12
June 24, 201313 yr Author it reallly has little use and not at a high level! anyone heard of other 2011 frames cracking? i have not heard of any? i wonder if gasgas uk will do ?
June 24, 201313 yr Ben as lineaway says talk to your dealer first, then the importer. although issues are worrying, give them a chance to help... this could be your lucky day :-) Cant see from the photo, but be sure its a crack? Sometimes at the edge of a weld a thin "valley" is created. This sometimes doesn't fill with paint so can look like a crack if it goes rusty. either way, have a chat with them. Dom
June 24, 201313 yr Ben, search this forum back within the last year. There was a thread about a very similar looking crack right along the weld. I don't recall the final conclusion, sorry. You already got good advice about checking with the dealer or importer.
