Radiator Leaking
My txt pro has a small leak , I've removed the rad But can't see exactly where it s coming from .
are the liquid weld products reliable or would it be safer to replace the rad?
I've just had a top end rebuild and don't want to risk knackering the barrel and piston.
id get it re furbished if you can it will probably save you a fortune
