Flywheel Puller And Manual
Hi here i am with yet another set of questions for your deliberation
What size thread is in the flywheel ie pitch and diameter as i want to make or buy a puller, i suppose they are left handed
Does anyone have or know where i can get a manual for the tr34
Does anyone have any spares they would like to part with
You chaps have been great so far and its nice to know where i can turn when im stuck
Thanks once again mark
Yes sounds easy i can measure the thread diameter but im unable to get into the threads with pitch gauges due to crank being in the way and thought if anyone could tell me sizes it would save a lot of messing around
cheers mark
:D yes it would be easy but my pitch gauges are too big to fit between crankshaft and flywheel
I realise you can spend a lot of money repairing a older bike but i have good reason to restore this one
I only paid
Good idea the modelling clay but managed to find some pitch gauges at work that will fit inside,will have to measure tomorrow and yes it was a runner before stripping just down on power due to bore wear .i will try to post some pics as rebuild continues
yours mark
cheers i was thinking of using a firm called dps who advertise in trials and mx news but i suppose they will just sub it out anyway so decided to send to langcourts
Thanks for the info i will be using langcourts for sure and for anyone who is intrested the thread on a tr34 flywheel is 26mm x 1.5 pitch and the 26mm is a right hand thread unlike on some machines which are coddy handed
cheers mark
