Beta Rev 80 2007 Water Pump Shaft
Hello all,
I need to replace the water pump shaft on my sons bike but cant find one. Does anybody know what other bike uses the same part.
thanks
i have been told that the 80 engine is the same as the ktm 85 engine might be worth doing a bit of research maybe a parts list good luck
Malcolm
The bottom end of the engine is the same as the KTM 65 (might also share with the 85 as already stated above). KTM used Beta to manufacture their small 2 stroke engines from 2002 - 2009 before they introduced their own power-valve engine.
Dom
Malcolm
Dom
Do you know where I can get a water pump shaft for these bikes? cheers
Malcolm
thanks Dom, i tried Beta but they are out of stock. By the way i am in Fort William.
Malcolm
