Grease The Exhaust Header Threads?
Just had my pipe off for a clean up while I also install some carbon tech reeds. When I put it back together is it best to use copper slip on the threads of the allen head bolts that go in to the barrel? What's the perceived wisdom of the Beta masses?
ive always put copper slip on - I do on every bolt I take out to be honest :)
My preference is to replace the allen bolts with studs and nuts if there is room. I see quite a few barrels damaged with crossed or stripped threads from use (misuse) of allen bolts
