September 5, 201312 yr Hi, I require a replacement lower rose joint bearing on the ohlins shock I have on my 2010 Beta Evo. Had a quick search on the net but can't find much so I'm just thinking if its the same as a the bearing used in the standard Beta shocks? Cheers, Sam
September 5, 201312 yr Try Splatshop http://www.splatshop.co.uk/ohlins-rear-shocker-bearpng-small.html
September 5, 201312 yr if you can take the shock off the bearing should have a number on it, any bearring shops should be able to get them for you.
