September 7, 201313 yr When re-assembling an Amal carb, should you put anything on the new float chamber gasket? Oil or grease? Or should it go in dry? Also, would you put a wee bit of grease or Vaseline on the rubber 'o' rings on the jets? Cheers D
September 7, 201313 yr When I fitted a new float chamber gasket I didn't use anything as the petrol might dissolve it, anyway the gasket should seal on its own. The O ring on mixture screw might need a little rubber grease to aid fitting the O ring into the groove, and the same with the slow running screw. The main , needle , and pilot jets do not have O rings fitted, as far as i know.
September 8, 201313 yr The gasket should go on dry, however, I have used a dab of grease if just refitting the float bowl to an awkwardly mounted carb - like the middle one on a Trident. As for O ring lube, why not use a smear of 2 smoke oil?
September 8, 201313 yr Author Thanks for the replies, it's now back on the bike and once I've got the air filter sorted we'll see how she goes. Cheers D
