June 16, 200521 yr gonna go colect my txt tomorrow hopefully. ive got a few questions that need to be answered. -what gearbox oil should i use and how much of it should i put in -is castrol tts ok to use as premix oil. if so what ratio should i mix it at. -what is th rear break like to bleed is it a pain in the a*** that takes ages to get the air out or is it straight foward put bleeder on pump lever done
June 16, 200521 yr Hi B B, I use Dextron III ATF in mine (TXT 2000 280) after searching these forums - it seems to be a popular choice. The manual says 750cc but i think that is from completely empty (i.e. new) or 650cc for an oil change as you never get all the old oil out. Having said that i reckon mine took more like 700cc. There is a level window on the side and the oil should come half way up this with the bike vertical. Give it some time to settle though and top it up if it looks low after you've run the engine. Castrol TTS also seems to be recommended and i mix it at 80 to 1. My back brake was a pain but it transpired that the master cylinder piston wasn't returning out enough. After fixing that (added an extra spring inside) it seemed easier to bleed it by using a screwdriver to depress the piston (with the brake pedal off) then set the brake pedal travel and height. Hope this helps and hope you enjoy your new bike. Roy
June 17, 200521 yr Where do you get Dextron III ATF from, cant find it anywhere? and whats the difference between normal Light trans oil? I've always used MOTUL Transoil 10w30. Seems perfectly OK.
June 17, 200521 yr Double checked and it seems that i'm using Dexron II not III, but it was v easy to get from the local motor factors. Halfords or any car parts shop should do it i'd have thought. Motul is some nice stuff, i use it in my Subaru, not cheap though! It's probably more important to change it regularly than pay a fortune for some posh stuff. All IMHO of course
June 18, 200521 yr Author got a few more questions. -how much coolant does it take. -how much fuel does the tank hold. -where can i got carbon fork gaurds from
June 19, 200521 yr Thank you for your captivating and charming response, may i respectfully suggest you try the search button?
June 20, 200521 yr If it is the pro you only need 400ml of oil in the box. Dextron III from Halfords, 19.99 for 5 lt not bad!
June 30, 200521 yr Now you tell me about Lucas !!! there is one about 20 seconds across the road from the Halfords I used For under a tenner it will be fine if you change it every week before it 'goes off' Edited June 30, 200521 yr by oceanvibe
