September 23, 201313 yr Took my sons Raga out for a ride yesterday. Very nice bike, but... The kickstarter seems to be a different type than all my other GG`s. Is there any others having trouble with foot sliding off?? I got a spare good old kickstart somewhere in my garage. Do you think it will fit? (Ill probably find out when I try...) -Jan
September 23, 201313 yr yeah should fit. someone had the same problem with there footslippng of on here http://www.trialscentral.com/forums/topic/44231-kicking-the-raga/ Edited September 23, 201313 yr by shercoben12
September 24, 201313 yr yeah should fit. someone had the same problem with there footslippng of on here http://www.trialscen...cking-the-raga/ FYI, the 2013 Raga has the full sized kicker on it (least the one we got). my 2012 has the one with the last 1/2 inch cut off the end, and i fight the ability to kick it as well, when wet out.
September 24, 201313 yr Author Thanks guys. Not only me then..I will definitly try the spare one I have. -Jan
September 24, 201313 yr my friend has got the a 2012 Raga and he doesn't like the kick start on it either, I have seen this product below. I have no links to the company selling the item just looks like a cure to the problem http://www.trialsuk.co.uk/products/rqf-gasgas-kickstart-lever
September 24, 201313 yr I am contemplating on having a welder add to the "bumps" to which I could then file on, make sharper, problem is I still have scars where kicker dug into calf, without being sharp, so swapping with starter from another year might be the right way to go. Funny TrialsUK shows red and black, sells black and "silver" go figure. I wanted the red one.
September 24, 201313 yr Yes, the 2012 kickstart was a pain, thankfully the 13 is back to the original size. Any other year will fit.
October 16, 201312 yr Had the same problem with my 12 300 Raga.What I did was remove the standard kick start lever retaining bolt and trade it for a allen head bolt. This moved the kick start lever when getting ready to kick from slightly behind perpendicular to the bike to slightly ahead so that my boot stays on the lever instead of wanting to slide off.Works much better and seems much less dangerous.
October 18, 201312 yr Author Had the same problem with my 12 300 Raga.What I did was remove the standard kick start lever retaining bolt and trade it for a allen head bolt. This moved the kick start lever when getting ready to kick from slightly behind perpendicular to the bike to slightly ahead so that my boot stays on the lever instead of wanting to slide off.Works much better and seems much less dangerous. You mean that the thicker allen head keeps the kicker "out"? Seems like an idea to try. Tryed fitting the old kick start I`ve had in my garage "for ever". Think its from a 02 or maybe 03. Did not work because of the wider frame one the newer bikes. -Jan
October 18, 201312 yr The bolt head is thicker so the lever does not rotate as far out before hitting the stop and being ready to kick.In that position it has worked much better for me when it is wet or dry.
October 18, 201312 yr The bolt head is thicker so the lever does not rotate as far out before hitting the stop and being ready to kick.In that position it has worked much better for me when it is wet or dry. Aaaah, now I get it.
