June 20, 200521 yr I have just bought some new 2004 tank stickers for my mont and i'm wondering how to put them on. Are they like the stickers you get in a little plastic model kit? .... praying for a rapid answer ....
June 20, 200521 yr if they are anything like the tank stickers i put on they are really sticky and once you have them on it is hard to get them off hope that helps also when you put them on start in one corner of the tank and make sure no air is underneath it, also when you are putting them on dont hold it with your fingers by the edge as it will not stick and eventually will come off
June 20, 200521 yr Slap some soapy water on the tank then you will be able to slide the sticker about till its perfect then just push some of the water away by wipeing the top of the sticker with rag or something, then leave it to dry and it will still stick to the tank like mad
June 20, 200521 yr Author but how does the sticker come off? do i have to wet it untill it lifts off the paper? or do i peel it off from the paper dry? Thanks for the replies!!
June 22, 200521 yr Author Great.... got the sticker/transfer on, but it looks really fragile. How long do these things last!?!?!
