September 29, 201313 yr Just wanting to know can a beta rev 3 be started without a kickstart as in bump started I think it can't be done as the clutch is hydraulic but I may be wrong any body gonna enlighten me on this cheers
September 29, 201313 yr Try at least fourth, it's much easier. As far as bump starting is concerned a clutch is a clutch is a clutch, method of operation is irrelevant.
September 30, 201313 yr Cable or hydraulic is irrelevant as mentioned The hardest thing is getting the tire to bite, get some speed, pull a little nose wheelie, push the back tire into the ground to make it bite and drop the clutch If it bites it starts but best of luck with the timing LOL
September 30, 201313 yr Author Thanks guys tried it in first and second no joy back wheel locking up . i snapped the kickstart and then got it welded and it broke again so was just curious where i was goin wrong . the kickstart well and truly had it now but i have a plan to construct one from a pit bike that will fit . no more tryin to bump it dont want to wreck anymore bits cheers
October 1, 201313 yr If I remember correctly the 2004 and 2005 rev3's had alloy kick starts, I broke one on my new bike back in 04. Earlier bikes had steel ones. The only thing that broke quicker than the kick start was the stator, and I had two of those go!
October 1, 201313 yr If I remember correctly the 2004 and 2005 rev3's had alloy kick starts, I broke one on my new bike back in 04. Earlier bikes had steel ones. The only thing that broke quicker than the kick start was the stator, and I had two of those go! Rubbish
October 2, 201313 yr i have a steel kicker off a Synt..i belive it will work... i have a local dealer that can order you a new Rev 3 kicker..heck an Evo kicker will work as well. PM me and ill give you his number
October 2, 201313 yr i sent you a link to Richard Allen.. he is a bit closer then me...and a great guy, http://www.allensusedtrialsspares.co.uk/#
