October 7, 201313 yr Hi, first time trials bike owner and rider, just after some info really on my new purchase, a 97 gas gas jtx250. The bike is fantastic to ride but I am still getting used to it as there is a lot to learn! One thing I did notice about the jtx is the tiny rear brake pedal! Are there bigger brake pedals for this bike off other models by any chance? I just don't like how hidden away it is, even though I understand that it has to be tucked away some what. Any help is much appreciated! Dan
October 7, 201313 yr Hi, Are you sure it's not bent, as they are not usually a problem. I have a 95 jtr and I think they are the same, The bush inside the lever can wear and makes the lever a bit floppy. Maybe that just needs replacing. TLTEL
October 7, 201313 yr Author Hi, thanks for the reply. Not sure if it's bent or not, it's definitely a little floppy, as in up and down play, but it just seems really close into the clutch cover... I'll have a closer look next time it's out.
October 7, 201313 yr Author In fact this is the bike I bought, you can see from the photos how tucked in it is.
October 7, 201313 yr Author Sorry, need a link don't you... http://www.ebay.co.uk/itm/GasGas-JTX-250-Trails-Bike-/221288618569?_trksid=p2047675.l2557&ssPageName=STRK%3AMEWAX%3AIT&nma=true&si=xCbuEVgYNhiQlmppp4LUEuilRe0%253D&orig_cvip=true&rt=nc
October 7, 201313 yr Author Sorry to keep replying to my own thread! But the kind of lever I would prefer is like the one fitted to the txt models. Looking at other gas gas's around my year, all of them seem to have these tucked away rear brake pedals. I'm too used to my dirt bike type pedals I think...
October 7, 201313 yr That is the standard pedal for the bike and is the same one for several years. Trust me, you do want it tucked on like that. I did find that I had to sharpen the teeth on mine when I had it to keep my boot from slipping off.
October 8, 201313 yr Author I might just try that then and re-position my foot on the pegs slightly. It's not as though I can't reach it at all, it's just not in the usual place where I expect a brake pedal to be. I guess they made it like this to prevent you from touching it accidentally when hopping up things?
October 8, 201313 yr You don't want your foot tight against the frame while riding,it'll cause a dab if the bike deflects to the right.
October 8, 201313 yr Yes, the pedal is designed to be close to the engine to prevent it from hitting things. It is not so much of a problem when jumping over things, but more when getting very close to something or having the pedal hit when the bike falls. A replacement pedal is about US $50 so you don't want it breaking too often.
October 22, 201312 yr i have the same bike 250 contact, and thought i had the same problem, but trust me you will get used to it, its there when you need it. Dan.
