October 18, 201313 yr Anybody got a inlet to carb rubber ? I've tried Martin and Jumbostu. Thanks Ross Must be the SWM straight one, not the cranked Aprilia etc.
October 18, 201313 yr Are the inlet manifolds Martin had sold out? There was an Italian resource, ... if in need I can look up?
October 18, 201313 yr Author Hi Patrik, Martin sells the manifold from air box to carb, but hasn't got any of the carb to inlet at the moment. Ross
October 18, 201313 yr Seems to be that 267 790 is sold out again, even in France as brp-rotax and Atelier bmz don't sell them anymore. As I know the replica manifold batch was made in summer 2012 in Italy, it should have been them: http://www.swm-moto.org/ You might ask them, if they have one left.
October 20, 201313 yr Right then fellas after talking about it for years next friday I am collecting my first SWM. Looking about where do you get specific swm bits like air filters, points (assuming its points) mudguards, pistons etc ? I dont need these bits now im just trying to plan ahead.
October 20, 201313 yr Author http://www.motoswm.com/ Glen, thought for a moment you were going to help me ! Martin at the site above has a huge selection of new and second hand parts. Rotax motors as you know are hardy beasts, a bit of slap is not a problem. Lots of helpfull, knowledgeable and smart people on here (that's why they have swm' s)
October 28, 201312 yr I need also one to my 125. If you find one let me know! Martin suggested he had some of the 125 carb to inlet boots. http://www.motoswm.com/
October 31, 201312 yr Author Will do, I've got a second hand one coming from a military bike, soon as its here and compared I will come back to you.
November 2, 201312 yr Hi Ross The military motor uses a Bing carb as its based around the early RSGS enduro motor. So the carb rubber will be too big for your Dellorto. I have a couple of new original 125 carb rubbers here.....but the hole on these is too small for the 320 valve and carb. Martin
November 3, 201312 yr I have a 320 that had a bing carb fitted and yes its bigger (this bike also had a different sort of clutch cover that I think Martin said was from an early Military??). At present its got some insulating tape round the Dellorto carb to seal it up. This is one of the ones where I wolud like to change it. Ian
November 3, 201312 yr Author Hasn't arrived yet, but sure I can have an adaptor made up in alloy and shrink fit it to the carb.
