December 4, 201312 yr Try asprin thins the blood which often is causes arm pump lack of blood supply to which maybe a root cause of youre issue. Asprin kills all of your vitamin C. Better yet, take 1/8 of a teaspoon of Epsom Salt in just enough water to dissolve it. It magnesium sufate and provides muscles with their needed magnesium so they don't cramp. Take before trialing and there should be no cramps. If you still cramp then you are sadly lacking in magnesium and can build it up over time. Shell fish and green leafy vegetables are food sources of magnesium.
December 4, 201312 yr Potassium is supposed to help with spasms and arm pump Potassium is great for normal blood pressure and is great in the diet but calcium and magnesium are the elements needed by the muscles and magnesium is usually the one missing.
December 5, 201312 yr I have a similar problem with the end joint of my thumb, when it sticks I can force it back but it goes "Snap" I think it's a Tendon or cartilage problem, maybe hyper extended? This sounds like Trigger Finger. I have it and it sucks. Mine locks bent, though. It's a form of tendonitis. The tendons move through a sheath (like a throttle cable!) and when the inner gets inflamed, it sticks in the outer sheath. Cortisone shots often work but I happen to be one of the unlucky few on whom cortisone has no effect, so I'm likely headed for the surgeon's knife. According to all involved, it's very simple; a small incision and a quick slice on the sheath to open it up and release the tendon. You can't put a price on good times like these!
December 5, 201312 yr This sounds like Trigger Finger. I have it and it sucks. Mine locks bent, though. It's a form of tendonitis. The tendons move through a sheath (like a throttle cable!) and when the inner gets inflamed, it sticks in the outer sheath. Cortisone shots often work but I happen to be one of the unlucky few on whom cortisone has no effect, so I'm likely headed for the surgeon's knife. According to all involved, it's very simple; a small incision and a quick slice on the sheath to open it up and release the tendon. You can't put a price on good times like these! You do Know what causes this, do you not! The Eyes go next!
December 9, 201312 yr Something I try and do is preserve my clutch finger for just sections. When riding between or waiting in a queue I will either use my all fingers or the two middle fingers and then when I'm about to start the section switch to my index finger. I also have my clutch biting near the bars as I feel I have more control of the lever with with finger wrapped around it.
December 10, 201312 yr Sounds like "Viagra Finger" A little known side effect of too much Viagra consumption
December 11, 201312 yr I think that would be "my finger won't relax" Seek medical attention if you finger is still straight after four hours
December 11, 201312 yr For me, it's just been decided. I need surgery on mine. Supposedly it's quick and easy with a relatively short recovery.
December 12, 201312 yr We have a guy that uses his middle finger for both the clutch and brake. His reasoning it gives him better grip on the bars. There now you have a new option Charlie!
