Tlr Fork Bushes
5 minutes ago, TlmChris said:
... It stays inside the lower legs and does not come out with the stanchions.
Failing to see how that could possibly work, to start with the coating is on the outside surface so this bushing is designed to slide against the lower leg bore and that would make it attached to the stanchion tube.  Any reason nobody ever shows the stanchion tube?
