Air Cooled Gasgas Reed Block
I have an aircooled Gasser with the alloy, push in carb, type reed block.
I think it is an 88 model.
Is it possible to change to a later rubber version for a better seal and if so from which model.
Also where can air filters be bought from?
Thanks
On a TY80 which has the same type carb fitting I just stick it in with a bit of neutral cure silicone (Hylosil)
Sammy Miller used to do older gas gas filters and at a good price
