January 7, 201412 yr Fantic Guru's, I just need a bit of help - I've added an 80 air cooled mono to the stable - similar to the one pictured below ...except normal 32mm forks and non reservoir rear shock. I could do with any manuals etc as I need 1- Fork oil capacities 2 - Gearbox oil capacities An in depth parts diagram would be ideal ..... Has anyone uprated the suspension so it will take a 12 stone adult ???? Thanks in advance for any help As always the wobbler
January 7, 201412 yr There are parts diagrams here for the model you have posted a pic of and some newer/older ones too (the 50cc parts diagrams cover the 75/80cc too); http://info.motorsyk...lekataloger.htm they aren't exactly what you want but may be of use. Edited January 7, 201412 yr by grib
