January 20, 201412 yr I have seen the extending plates to weld onto the standard swing arm, however is there a longer model from another bike that will fit? I have a mini majesty frame that came without a swing arm and am looking to extend by 2 to 3 inches. Any photos of your solution welcome.
January 20, 201412 yr I used a swingarm from a 1975 DT175 it is longer then the Ty175 arm by about 2.25 inches. It needs the brake arm mound cut off and moved. I'll post pictures when I get to my laptop.
January 21, 201412 yr Here are the Pictures of my TY175 with a DT175 swingarm I hope As you can see I moved the front mount closer to the engine. And as the DT175 swingarm is wider at the back then the TY175 arm I had to use a 1/2 inch spacer on the left side. Edited January 21, 201412 yr by bestrcpilot
