January 24, 201412 yr Hi everyone, newbie here. Could someone advise me on where to get a softer rear shock spring for my daughters 2012 gasser 125. She is only 7stone and the shock on at the moment is too hard. We are intending on traveling from the Isle of man, to do the girls British championship this season, so I need to get her bike set up properly! Cheers Steve
January 25, 201412 yr Not sure you can get a softer spring without investing in an ohlins shock. Then you get the choice of 3 different springs I belive. As well as adjustable damping rebound etc. should be able to pick a second hand one up no worries or I think there on trial enduro direct
January 25, 201412 yr Just looked on splat shop...they have the separate ohlins springs and the weight conversion chart to pick the right one based on your daughters weight. Check it out http://www.splatshop.co.uk/ohlins-rear-shock-spring.html
