January 26, 201412 yr hi my mix screew is set at 3 1/4 turns is this correct for this carb can any 1 help plbl26 stamped on lelf side of carb
January 26, 201412 yr Almost sure should be between 2 1/2 to 3 1/2 out,plus remove your plug to check the colour,to see if it running weak or rich. https://www.youtube.com/watch?v=1EbXacjIV78 Edited January 26, 201412 yr by bilks
