Rev3 Wont Idle
Hi guys , looking for some advice.
Ive just bought an 06 rev3 200cc and on my first proper ride I noticed it wont idle properly.
If you give it a blip every now and then, its ok. The problem comes when youre not able to gove it the blip.
I was coming down a hill and concentrating on staying on the bike and it died.
Anybody experienced this? Any suggested jetting?
Have you tried adjusting the idle screw when warm.Not every 1 has a tacho,but you should be able to adjust the idle screw.to get a decent tickover , and also check your plug to check mixture strength.also if float level on the low side can give same results.
Edited by bilks
Thanks bilks. Ill try that.
The carb has been off, stripped and cleaned and refitted. I'll try the adjustment screws now that I know what does what.
I had the same thing, turned the fuel air screw (not by much) and its been great since.
Warm the bike up.
Mark where it is with paint.
Then moved 1/4 in/out until it ran clean.
Then adjusted the tickover.
Edited by petecam
Warm the bike up.
Thanks.
I'll give it a go :)
And, after it's set perfectly
They will still want to run rich on steep downhills, you can't fix it so you will need to pull in the clutch and blip
Very common for the Mikuni equipped Betas to stall on downhills. Mostly due to the angle of the carb which is optomized for power while climbing. Once the bike is jetted properly for the flats the stall can usually be abated by proper adjustment of the floats and turning up the idle speed just a bit.
Hi, I had the exact problem on a 2006 rev 3 250 cutting out when on a slight downhill.
I sent the carb to BVM in stroud and they changed the needle valve seat and set the tangs
on the float height.
It cost £48 with post and it run/idled spot on, problem gone !!
