Vivaro Primastar Traffic
anybody using one are they any good ive heard the gearboxes are weak i was also wondering if i could fit 3 bikes in a lwb crew cab any opinions would be appreciated my transit got written off by a micra on the m6 on saturday
  • Replies 30
  • Views 12.5k
Most Popular Posts
  • http://www.bbc.co.uk/programmes/b04plphs See above, From comments made at end of last program it sounded as if the vans involved may be same as this forum subject. If you watch last 5 minutes of epis
Ive got a swb Vivaro after having a swb Traffic before.
Yes, it will take 3 bikes no problem. Ive had 6 in mine without the front wheels in , but i wouldnt recommend that many.
Ive racked up high mileages on both and i havent had any gearbox problems although ive heard of them happening. Youve just got to be gentle with it. You get people just jerking and forcing it into gear and then surprised when the linkage goes. Its only the external linkage nothing inside.
They are very reliable.
Ive had no gearbox problems.
One steering / suspension arms wears and needs replacing every third mot , but they are only £100 fitted for both sides.
My 1.9 turbo has more then enough go and gets about 45 MPG empty and 35 MPG full.
The rear door handles need respect - dont just yank at them .
Would i buy another - yes
just turned 100k in mine..
it does 40mpg
eats motorway miles
cheapest tyres last about 20
repairs
1 clutch
couple of pairs of windscreen wipers
2sets front pads
1set rear pads
1 main fuel pump
pair rear wheel bearings
THE ELECTRICS ARE CACK
rainwater leaks into the cab
the rear door alarm sensor is pants.
yes i would have another.. its earnt its way and in 10 years its done 100k been used as a mobile tool shed and bike transport i d probably get 2k for it today and i paid 11k .. cheap motoring
I bought one last year 04 trafic 90000 miles one owner full service history only had light work thought I was onto a winner , couldnt fail three months later one gearbox rebuild, a turbo boost sensorand 2 crank sensors later and about £1000 light I cut my losses and bought a vito .ill never buy french again
I've got a 2006 Vivaro 2700 CDTI 1900 diesel which is the LWB crew cab. Regularly carry 3 trials bikes, could maybe get 4 in but not wanting to run the risk of foot rests damaging each other bikes.
I've replaced a ball joint on mine for its Mot but apart from that it's great.
Drives like a car, excellent mpg, 6 speed keeps the revs / cost down.
I've read all the horror stories regarding gearboxes but mine has been spot on.
We use them at work, they get hammered, (Vivaros) seem good vans. Apparently the Renault has a car gearbox so not as good. LWB drives better on a run than swb.
It is a common thing for the boxes to go. The fix is usually over a grand. One pal has had nothing go the other a gearbox at 60k.
Edited by nigel dabster
Every one I have known with this Renault/Vauxhall/Nissan van which is at least 8 people,6 have had fatal gearbox issues between 100-130000 miles !
(One just recently ) so beware if you do go for one !!
Stay safe !
I wanted a vito for years, finally got one but the rear diff went noisy within a week and within a couple of weeks the garage got sick of trying to fix it and gave me a refund. Bought a trafic next and prefer the trafic to drive plus better mpg. Its has had a clutch but other than that its been ok and I'm now up to 80k
Ive had seven vitos two over 100k,never had a diff whine yet, think you were unlucky.
the problem on the gear boxes was with the 2003 and earlier models I believe, we had 2 renault trafics never missed a beat- 4 bikes no problem just put a tyre or kit bag between them all.
thanks for all the replies just waiting on the insurance pay out
