February 25, 201412 yr My 4RT came with some Trials cast snail cams and whilst I like the larger diameter, I'm looking for some thinner width ones, so not to compromise the threads on the wheel spindle Any recommendations?
February 26, 201412 yr Had the same issue myself. I ended up not being able to use the first set of snails I purchased because of their thickness not working with the standard 4RT axle (greater than standard thickness meant less thread available for the nut to hold onto). I bought snails from V-mar instead that are recessed to suit the 4RT axle and shaped to hold the axle end and stop it rotating. http://www.vmar.com/snail.html FYI I'm Not connected to Vmar in anyway, just a happy customer; which is way better than being an annoyed customer having bought a set of snails, paid to have them posted to me half way around the world, only to find they don't fit! Edited February 26, 201412 yr by ross brown
