Beta Rev 3 2006
going to look at a rev3 2006, what do I need to check or be aware of, ive never had a beta so any info advice is most welcome
tia
tony
Anyone with a better answer or a bit of info
Ask if its had the stator replaced and how many times. Ask if its had the water pump seals replaced.
Those were the main issues of that era I believe. .
Thanks for that, is that about the only main issues with them, what does it cost for stator repair if needed
Thanks
Tony
Okay for starter bike-old bike now and so dated but still performs well if previously looked after.
Poor spark so difficult to start leads to replacement stator also water pump needs checking.
Call beta uk for prices they are very helpful
gave it a good look over and all is well, started first kick and stopped it and restarted it with no problems, stalled it and it restarted
i bought it as a toy realy, too old to compete nowadays lol
sorry im a bit off topic also have a beta 250 can i put putoline 4+ 15 50w in i know its 4 stroke tranny oil but will it be fine in my beta new to the game cheers all
No, it is way too thick. It would cause a lot of clutch drag. ATF was usually used.
thanks for that mate so stick to atf then must just need to warm it up before i use it normally takes around five minutes just to impatient and only ever rid mx so still getting to know my bike luv it though cracking bike in my opinion
When you get it started from cold pull in the clutch but don't put it in gear and the plates will separate
Tony
