Replica Gas Gas Brake Pipe Damaging Fork Leg
I have a 2013 gas gas raga replica and I have noticed the damage that is being caused by the front brake hose rubbing on yoke and right hand fork leg I have spoken to other replica owners all with the same fault I e mailed gas gas uk about this problem they said they have never come across this fault I also checked with gas gas parts the clip holding the hose is correct for model eventually the fork will leak because of hose rubbing coating off fork if you have replica check for same damage if so take some pictures and send them to gas gas along with frame no. These parts are expensive to replace Yours Chris laws.
If the upper clamp is straight inline where the brake line comes through the fender brace it should never rub. Unless we are missing something here.
My bike is exactly the same in your picture but when forks compressed the hose moves the clip guiding the hose then contact is made on fork leg. Ps new clip fitted Still the same
Thanks but when you spend £6000 pounds on a supposed too be top of the range machine you don't want to tape it up Gas gas should sort it out. .?
Dont route the hose through the mudguard brace but zip tie it the front of the brace. Also fit a cable guide from a sherco, splatshop sell them for a couple of £s, and fit to the number plate.
I cut the clamp down so it nipped up tighter and glue innertube on the inside then placed it higher in the middle. Also rerouted the brake hose as is ran inside the clutch hose holding it in.
I wouldnt normally bother but mine as the red forks.
