April 18, 201412 yr Hi guys my clutch has started dragging really bad after removing the oil Cap cover from the master cylinder the oil was bone dry . I removed the clutch casing to find there is a leak coming from the slave Seal cylinder is it just symply a case of changing the o Ring Seal on it and if so where can i get theese from ?, Thanks
April 18, 201412 yr It comes with the piston if I remember, and wasn't that expensive. Don't forget to pump the old piston out of the cover before you drain the brake fluid or it'll be hard to get out. Craigs motorcycles will get you one.
