Torque Setting For Rear Wheel Nut 99 Techno
The title says it all really...
Just adjusted the chain and need to tighten up the rear wheel spindle nut..
Have had a search on here but nothing popped up and the owners book is.....well, vague on info about anything really.
So folks...how tight does it need to be please
Thank you :)
Beta uk would tell you if no else knows I asked the same for my rev I can't remember what it is but I did it once and it was as tight as it would go and I've just used a Allen key to hold back and a 24mm 10" ring spanner since.
You could do that and then check it when your back at the van when your having a break.
The Evo has a pretty good manual by the look of it but the Rev ones don't contain much either.
The Evo manual probably got the torque measurements that would be a indication.
It's 80Nm on a 2011 Evo (24 mm nut also) so it could well be the same.
Thank you :)
I`d be more worried of the adjustment of the chain tensioner. Too tight and there goes the rear hub.
