Smokey 2011 Evo 250
Hi Guys, been out this morning for a couple of hours, after an hour or so I topped up tank and off I went again, after about 10 mins I noticed the bike was smokey ( blue, It wasn't prior to topping up ,so whipped out the plug ( bit oily ) and replaced with a new one I had handy, I gave it a blast along a dirt track a few times but still smoking a bit, I notice the bike was a bit sluggish on pick up too. I realise it could be a mixture issue re the oily plug but any help would be great. Im running V Power fuel with 75ml per 5 Ltrs.
Thanks in advance :icon_salut:
Sounds as if its running too rich.
Check air filter is clean and LIGHTLY oiled
Check float level
Check cold start enrichment is seating / sealing properly
Check float valve is shutting off fully
The above are all basic carb servicing, if this does not sort it check and maybe change your jet sizes and / or needle clip position.
