May 22, 201412 yr Does anyone know if the Jitsie aluminum EVO water pump impeller upgrade fits the 4t models? Everything I can find online just says for EVO without mentioning 2T or 4t. OR any similar part for the 4t? Thanks.
May 22, 201412 yr They have different part numbers, so I suspect it is a no go. Also, the Jitsie catalog only lists a 2t specific wp impeller. Edited May 22, 201412 yr by laser1
May 22, 201412 yr Costa Special Parts list one on page 22 of their catalogue: http://www.costaspecialparts.it/eng/prodotti.htm
May 22, 201412 yr Costa Special Parts list one on page 22 of their catalogue: http://www.costaspecialparts.it/eng/prodotti.htm I suspect that is a 2T impeller and will not fit the 4t. See post above about part numbers.
May 22, 201412 yr Author Thanks but it also is a single part for Beta with no indication of whether it fits the 4t (or only the more common 2t)?
May 23, 201412 yr It does only fit the 2T, Not the 4 stroke, The Impellor will probably be the same, But the spacer for the casing is different, We run a 2010 Evo 300 4t, And never had any problems with the pump or overheating, Edited May 23, 201412 yr by benbeta23
