June 30, 201412 yr hi. Is there a specific way to remove the kickstart on a txt pro 2010 ... My kickstart seems to be in the wrong possition so had a bash at removing it last night, took out all the bolts holding it in ect ect but it is well and truely stuck on the shaft !! any tips would be gratefull , cheers in advance. Ian
June 30, 201412 yr Had the same problem on my 2013 Factory. Put plenty of ease out fluid all around the knuckle joint, leave to soak for 24 hours. Remove kick start to leave the knuckle joint, do not level against casing as it may crack and that's £100 to replace. What you need is a two leg puller to side behind, use an allen bolt and screw/pull off. A couple of taps before you start seems to loosen the seizure. Apply plenty of copperslip before you re-assemble.
June 30, 201412 yr You loosen the bolt slightly (Do not remove) Then just open the kick start. It basically will pry it self off. Fast and easy once you have done it.
June 30, 201412 yr You loosen the bolt slightly (Do not remove) Then just open the kick start. It basically will pry it self off. Fast and easy once you have done it. As above, its simple once you realise.
