September 6, 201412 yr Those small vents or black screens on th erear fender keep popping off...what kind of glue will keep them in place? Tried a number of them, but all eventually pop back off. Thanks Tom
September 6, 201412 yr Not actually done the job owning a GG but 'Shoe Goo' is perfect for these kinds of jobs. It's like a silicone sealant but incredibly resiliant to peeling off/moving. I use it in combo with glass fibre matt to repair mudguard cracks before they get too bad. Search for it on flea bay. Edited September 6, 201412 yr by itsafive
September 7, 201412 yr Author Not actually done the job owning a GG but 'Shoe Goo' is perfect for these kinds of jobs. It's like a silicone sealant but incredibly resiliant to peeling off/moving. I use it in combo with glass fibre matt to repair mudguard cracks before they get too bad. Search for it on flea bay. Not actually done the job owning a GG but 'Shoe Goo' is perfect for these kinds of jobs. It's like a silicone sealant but incredibly resiliant to peeling off/moving. I use it in combo with glass fibre matt to repair mudguard cracks before they get too bad. Search for it on flea bay. Thanks ....
September 7, 201412 yr I think the original adhesive is "hot" glue and yeah mine popped too. I reglued them with a hot glue gun.
September 7, 201412 yr I did what Dan did and when that eventually popped off, I used some SuperGlue between the spread of old glue and the plastic fender and then clamped with tiny clamps and iceblock wooden sticks for a few hours. This seemed to work well. So essentially superglueing the spread of glue to the plastic of the fender.
September 8, 201412 yr I took the mesh off, cleaned all the glue/silicone both the mesh and the inside of the mudguard,t then clamped the mesh back into place and went round the edge with a soldering iron and melted the plastic into and over the mesh that overlaps the mudguard (obvioulsly on the back (inside) of the mudguard) ****MAKE SURE YOU DO THIS IN A WELL VENTILATED AREA**** Have done this on both mine and my lads 2011 Beta Evo's, also I think it doesn't help that the mudguards are so long i.e. one piece, we both have the Top Trial Team style two piece flexible mudguards (yes we've both looped our bikes at some point or other!) so if you do bend the new rear mudguard the force stops half way along (at the join) and doesn't transfer on along to the meshed area. Also covered the mesh with clear silicone to stop the water getting into the air filter area, never had a problem with the bikes running since I've done them, that last tip came from Steve Saunders, I would suggest the bloke knows what he's talking about! Edited September 8, 201412 yr by wheeliebealie
September 8, 201412 yr Author Interesting about blocking th event and sealing it up with silicone...maybe just glue some black plastic on the back side and block off completely?
September 8, 201412 yr I've done a tiny bit of plastic welding with soldering iron. It can work well with a bit of practice. You can make it neater at the end by using a heat gun to smooth out. You can also remove scratches pretty well with gun as I've already done on wife's trail bike front guard. Handy tip... Keep old mudguard handy and you can cut slivers off with a pocket knife, makes great filler rod when you need more material as in covering the mesh edges. Mags
September 11, 201412 yr I stuck one of my vents back on with a hot glue gun last night. Worked ok. Bit messy, but was my first attempt
September 16, 201412 yr Author Pre-bent the vents somewhat in a curve to match the fender…note: somewhat. Cleaned up the fender well, prepped with alcohol then use a GE product called Silicone Glue. Clamped and let set for 12 hrs…will see how it holds up.
