Kickstart
Hi,
Recently purchased a 2004 Txt Pro 249.
My son has managed to shear the engagement gear on the kickstart.
Contacted Gas Gas and they have sent up a new gear but my old gear was the quadrant style and the new one sent is the full circumference style.
Are they compatible?
I did go online and ordered by the part number as per the Gas Gas manual, so not sure if this is an upgraded version?
Thanks in advance
Zippy,
Thanks for the response but are they compatible?
I ordered the quadrant style as per the part number on the Gas Gas website but have been sent the full circle
Thanks Bilks,
Gas Gas have sent the wrong part!
The quadrant type fits onto a spline which the full circumference one doesn't have
Bilks, I like that picture. Only on a gas gas is it normal wear and tear to break gears.
Gee Line, tell him the rest of the story why don't ya!
It would seem as though GasGas PRO kickstarting gears have some issues.
Proper starting technique will generally alleviate the problem.
Do not "stab" at the kickstart.
Take up the slack in the kicker slowly with your foot and then use a firm, swift downward kick.
Some do not recommend this: My kicker has been moved forward one spline on the shaft. This allows just a little more spin for easier starting. I am the second owner and the first owner had done this starting when new in 2003. No problems as of yet to be attributed to moving the kicker forward.
