September 29, 201412 yr How can i remove the steering bar clamps from a gg pro 2008 tripple tree? Since the bolds are underneath the bar holder.
September 30, 201412 yr Author Actually thought about it, but this does not solve my problem. Do i need to drill out the pins on the side? Because how am I going to mount them back on again? I can also just trow them away and mount others I have laying around, but would be a bit of a waste of the good clamps. /read your statement again and so my plan is the same as yours! Edited September 30, 201412 yr by crazybond700
September 30, 201412 yr You don't need to drill them they're just pushed in you can tap them out with drift of smaller diameter than the pin then tap them back with a small hammer when you refit them
October 1, 201412 yr Author Ok, thanks. Will have a look next time when i am in the garage. They looked a bit like rivets to me, so I thought you couldn't get them out without damage to them.
