Recommended Engine Oil For An Sy250
Is there any type of engine oil that people recommend above the others for an SY250? I've just got myself a second hand one that has been filled with bog standard engine oil - it's running a little hot and the gears seem a little clunky (I'm not certain the oil is the cause, but it needs doing anyway), so I'm hoping to give it an oil change asap.
I'm using BelRay Gearsaver 75wt. transmission oil for 2 strokes. I believe Scorpa recommends the Motul equivelant. Smooth as butter.
